How do you mount a speedo drive on a Dayton wire wheel hub?
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Tue Feb 13, 2024 12:46 am
I told like to mount a speedo drive on a Dayton wire wheel hub and am looking for ideas on how to do it from folks who have. I have the hubs and a good Stewart speedo drive.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: How do you mount a speedo drive on a Dayton wire wheel hub?
Post by Dan McEachern » Tue Feb 13, 2024 1:44 am
Buffalo hubs (not all) have three tabs that protrude out from the inner edge of the hub to mount the road wheel using three machine screws. Seems Dayton hubs may not have this feature, but you could make up three tabs and tig braze the tabs on your hub- In the picture below you can see one of the mounting tabs behind the road gear. Another method- Stewart made a road gear with about a 3" diameter center to mount on year? a Ford hub that had a machined feature on the inner edge to mount a road gear- locate one of these and machine the inner edge of the Dayton hub to clean up and then make a spacer to mount the road gear that way. Sorry, this picture is not the best, but you can see the mounting tab, and this road gear is the one with the small center hole to locate it on the hub.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Tue Feb 13, 2024 10:36 am
Thanks Dan. Those are good options.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Post by Russ_Furstnow » Tue Feb 13, 2024 2:07 pm
I have a set of Dayton wire wheels, and the Stewart road gear that fits the wire wheel hub is #8685. There are no "tabs" to screw the gear to, BUT the hub is machined to accept the 8685 gear so the runout is perfect. The gear and hub are nearly a press-on fit. I hope this helps. Russ Furstnow
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Feb 13, 2024 2:11 pm
Russ is showing the same road gear as in my picture. It would still be possible to drill and tap the hub flange and use long screws to hold the road gear afainst the hub if your Dayton hub has the machined shoulder, if not then simply machine the hub smooth and make a spacer ring if necessary to center the gear.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Tue Feb 13, 2024 3:29 pm
Thanks Russ. Was the friction alone enough to properly mount it?
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Tue Feb 13, 2024 3:34 pm
While there was some friction, there will need to be something more to provide a tigher fit or screws to the gear. As Dan mentioned, you may need to braze or weld on some tabs to screw the gear to the hub. Russ
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Feb 13, 2024 6:22 pm
Those tabs really complicate the manufacturing of new hubs, so I leave them off. To add that capability I make a ring that shrinks on to the hub. Brazing or welding will likely cause distortion of the bearing bore, but I have found that a .002” shrink fit is enough to retain the speedometer gear without distorting the bearing bore
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Wed Feb 14, 2024 11:43 pm
Thanks Kevin, that looks like a good way to go. Maybe add some green loctite stud and bearing mount as well.
Post by Allan » Thu Feb 15, 2024 4:24 am
Might the firm fit of the gear be supplemented by the use of scotch screw or two to act as a positive lock to hold the gear in place?
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Fri Feb 16, 2024 12:42 am
Allan, my Aussie to Yank dictionary failed me. What’s a Scotch screw?
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Fri Feb 16, 2024 2:40 am
It seems to be a screw with a 3M adhesive product applied to the threads, Scotch trademark.
Post by Allan » Fri Feb 16, 2024 5:58 am
A scotch screw is used to hold fixed components in place. It involves drilling a hole in the interface between two components, tapping a thread in the hole,and screwing a screw/bolt into the hole. In this application, it would stop the gear turning on the hub, at the same time stopping it from migrating off the hub. One might do. I would use two, diametrically opposite each other. If clearance is a problem, the screw could be a grub screw with a hex internal drive.
I used this method to adapt a fat man steering wheel to one of my T models.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Fri Feb 16, 2024 10:00 am
Thanks Allan. I have seen that done but never heard it called that. That would keep it from rotating. If the plate used for the tabs was thick enough, it might be possible to achieve the same effect using set screws threaded through the side of the plate and bearing on the hub. This would obviate the need to modify the hub itself. I try to limit irreversible alterations to rare original parts. Though I am happy to do it to common ones for the Speedster.
Post by Allan » Fri Feb 16, 2024 7:21 pm
Morgan, it not only stops it from rotating, it also stops it migrating sideways off the hub. Two screws would remove a total of one hole in the hub. This is easily filled later, if needed.
