Loose timer control lever
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Tue May 21, 2024 10:07 pm
The timer control lever is loose on the end of the rod. It moves back and forth a little so either the rivet is worn, the hole in the lever or the hole thru the rod. I am not sure of the diameter of the pin or the holes. If the hole in the rod is worn I was thinking about inlargeing it to a size a spring roll pin would secure it. What have others done?
Re: Loose timer control lever
Post by Allan » Wed May 22, 2024 12:22 am
I have chosen to ignore play with that little arm more than once. If you have ever fought to get one of those off at any time, you might do the same. The play is of little consequence as long as you can still get the range of timing adjustment at the lever.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed May 22, 2024 12:42 am
I slightly enlarged mine, threaded it and put in the smallest filster head screw I could find and put it on with some locktite.
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Wed May 22, 2024 7:27 am
Snyder's sells a replacement lever arm and the pin to hold it in place for a very reasonable price. I replaced the worn out arms on both of our T's and it is nice to have that extra slop removed. Here's a link to the arm in their catalog
https://www.snydersantiqueauto.com/prod ... &cat=41907
Post by Jerry VanOoteghem » Wed May 22, 2024 9:05 am
FWIW, the pin diameter is 3/32".
Try removing the arm, or at least the pin, and test/inspect the holes in the arm and rod with a shank end of a 3/32" drill bit. Check for looseness. Maybe all you need is a new pin. I'm not a huge fan of split pins in a T, but this location would probably be okay and would make up for any wear in the holes. Or... just go with the Snyder's fix mentioned above.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Wed May 22, 2024 11:53 am
I put "Rod Ends" on my timer and throttle.
I don't have any play in either one now.
Respectfully Submitted,
Be_Zero_Be
Post by Original Smith » Wed May 22, 2024 4:52 pm
I don't recognize any of those rod ends. I have originals on both my cars, which are 1913's.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Wed May 22, 2024 6:56 pm
These are non-stock additions I made to my '16 T.
https://www.racecareng.com/item/1579972 ... ory=113424
Be_Zero_Be
