Shop class
Re: Shop class
I wish I could see more of the car in photo number eight. It appears to be a theatre or vaudeville group and probably has their names on the car. I haven't been able to pull it out (yet?), but I could swear I have seen those people in those costumes before. Anybody know who they are?
- First Name: Susanne
- Last Name: Rohner
Re: Shop class
Im guessing that the kid at the bress is learning the fine art of straightening on a manual press - my guess is he;s doing itusing a piece of pipe or tubing (looks unfamiliar as a car part), but using something like that he could look down the inside of the pipe and see if it's straight or not (which would be readily apparent) before trying it on something solid. Also trying to figure out what the kid working on the flywheel is torching (I think it's a torch he's holding). Then there's the guy up to his forearms in the crankcase of a motor (with field coil attached)... All in all a fun photo!
Re: Shop class
Pan straightening
Re: Shop class
Great photo ! It appears that he using a T driveshaft for leverage !
- First Name: Vernon
- Last Name: Worley
Re: Shop class
27 Business, Vale Oregon is now 100 South Court Street.
The building remains intact as does the one across A Street.
Vern (Vieux Carre)
Re: Shop class
I think the whole shop scene is staged for the photo. For one thing, the press is centered over one of the troughs in the pan cover. I can hardly believe that if they were really trying the straighten the pan, they would be doing so by pushing against the still attached cover. Also, the guy with the driveshaft seems to be serving no obvious purpose in any kind of straightening set-up. The others also seem to be involved in other pointless operations.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Re: Shop class
Good Lord! that group on photo # 8 ! They look like the cast of some small time traveling show. “I’ll be back at 3 o’clock and you’d better have the mortgage money or you’re in the street!”
- Last Name: Rohner
Re: Shop class
Silly me, I didn't see the pan! Must be getting old!
I was looking at the pipe, rather than the pan, thinking it was just part of the press...
The one guy checking clearances on the pedal to (aluminum) hogshead interface was a maybe, until I realized he was holding needle nose pliers to hold it... also, the guy heating up the ends of he magnets on a radiator bench was... um... interesting. Heaven help us, DO NOT let some AI get this picture, they'll start using it to instruct people how to "repair" their model T...Jerry VanOoteghem wrote: ↑Wed Jun 26, 2024 11:15 amI think the whole shop scene is staged for the photo. For one thing, the press is centered over one of the troughs in the pan cover. I can hardly believe that if they were really trying the straighten the pan, they would be doing so by pushing against the still attached cover. Also, the guy with the driveshaft seems to be serving no obvious purpose in any kind of straightening set-up. The others also seem to be involved in other pointless operations.
- First Name: Paul
- Last Name: O'Neil
Re: Shop class
I just love that moody atmospheric shot showing a rainy street scene. It could almost have been intended for the cover of a detective book. It would be interesting to know who took it and why. There is no discernable subject, its just a scene from life like a painting.
Paul
Paul
- Last Name: Patrick
Re: Shop class
Wayne. Here is another picture of the actor’s Model T in Newlife, Wisconsin. I found it by searching “General Store, Newlife, Wisconsin”. Jim Patrick
Re: Shop class
Thank you Jim P! A real day brightener to see this.
Re: Shop class
Glad to help.
- Last Name: Bartsch
Re: Shop class
Thanks, Jim P, I had looked carefully at that pic, curious about the Wisconsin connection. Thanks for figuring that out and sharing.
I'm sure Steve Jelf knew/knows all those WTMJ Personalities well, can't wait to hear his report
