Pan Jig Layout Dimensions
BE_ZERO_BE
Topic author - Posts: 656
- First Name: BOB
- Last Name: CASCISA
I am in the process of building a pan straightening jig.
Two files are attached of the hole pattern layout for a pan jig.
The first one is the Ford drawing of the long nose pan.
I made some red line markups to clarify the drawing for reference.
I also discovered an error in one of the dimensions.
The second one is a CAD drawing of the hole pattern with dimensions.
I deliberately over-dimensioned this drawing so I could verify the position of each hole against the Ford drawing.
Hope this is useful.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Re: Pan Jig Layout Dimensions
A few years ago, I had an opportunity to buy a circular piece of of plate steel about 1 1/4 " thick and 50" in diameter. It was new material left over from making some piece of machinery. I wish I had bought it.
BE_ZERO_BE
- First Name: BOB
AS the project progresses, I will add drawings for the false fourth main, the crank hole alignment pin and other details.
Be_Zero_Be
Be_Zero_Be
BobShirleyAtlantaTx
- First Name: Bob
- Last Name: Shirley
One heads up. Several years ago I built a pan jig from drawings off the forum, the nose holes were reversed. No big deal I have an extra couple of holes. But, I would suggest you lay out your holes, then set a pan on and check your layout before drilling. And a magnetic drill and and a tapping fixture really makes the table turn out nice.
BE_ZERO_BE
- First Name: BOB
Other Bob,
I reversed the layout to be correct for an upside down pan.
Be_Zero_Be
Be_Zero_Be
BobShirleyAtlantaTx
- First Name: Bob
. The centering jig at the back is upside down for the picture but, this makes it easy to pull the pan into alignment. The plate was cut with a track torch. If I can help 903-824-1949 and no I won’t donate to the police officer fund.
BobShirleyAtlantaTx
- First Name: Bob
I feel it’s very important to establish the center line and lay out every hole off of it.
BE_ZERO_BE
- First Name: BOB
Other Bob,
I like your setup for lateral movement of the pan tail.
I may steal that idea.
Be_Zero_Be
Be_Zero_Be
BobShirleyAtlantaTx
- First Name: Bob
Mr Bob the idea is yours for the taking. It dose make getting the back of the pan correct, simple.
Bryant
- First Name: Bryant
- Last Name: Shafer
While we are on the subject
Bob how much overhang did you leave for the straightening jig at the back of the pan? I see the pan is 40-15/32. What ended up being the total length of the plate?
Bryant
Bryant
- Last Name: Tannehill
Bryant unfortunately my friend Bob Shirley is on permanent tour, such a loss to the family and his friends I miss him often especially when I’m trying to figure something T related out. However Bob Cascisa is active as can be.
Best John
Best John
Bryant
- Last Name: Shafer
Well, that is unfortunate and Iam sorry to hear that
I was looking for something exact, but I guess I could guesstimate before I order the plate steel.
Bryant
Bryant
Drew Wommack
- First Name: Drew
- Last Name: Wommack
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Touring, 1923 Speedster, 1925 Roadster, 1926 Touring
Bryant,
I now own the Bob Shirley table. It's at my warehouse/shop but I will be up there tomorrow and can give you the dimension for the rear extension.
Bryant
- Last Name: Shafer
Hey thanks Drew I appreciate that
Thank you!
Bryant
Thank you!
Bryant
Drew Wommack
- First Name: Drew
Bryant,
See below some additional photos of the pan alignment table. It's hard to see since the table is dirty, but on the rear adjustment plate (2nd photo)there is a small indexing mark for alignment with the centerline cut into the table. The plate is 42" in length and extends 2 1/4" past the rear of the pan.
Drew, so happy you are using the pan table Bob built. The actual last thing Bob did T related was straighten an early pan for a friend in northeast Mississippi after no one else would do it, he charged him $0.00 !
When the pan arrived back after completion it slid in perfectly aligned to the straightened frame. Bob said the pan was so crooked that it must have been owned by a politician. I miss Bob, one of the good guys. RIP.
Bryant
- Last Name: Shafer
Thanks drew for the information
Bryant
Bryant
