1910 rear strap
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
1910 rear strap
Post by Rod » Wed Aug 14, 2024 9:53 am
Does anyone have a picture of the rear strap? I had a new top installed but I’m having trouble with the rear strap. Here is a picture of what I came up with but I don’t think it’s correct. The saddle has a larger slot on one side and two round holes which I have no idea what they are for.
Re: 1910 rear strap
Post by Jerry VanOoteghem » Wed Aug 14, 2024 10:06 am
I believe you basically have the strap laced through correctly, however, the 2 small side holes are for rivets that hold the strap in place and also force the strap to lay all the way down in the bottom of the saddle.
Fire_chief
First Name: Charlie
Last Name: Gagel
Re: 1910 rear strap
Post by Fire_chief » Wed Aug 14, 2024 2:14 pm
The original strap was made up of 3 pieces of leather, rivited together . The two shorter pieces were riveted to the two holes in the bracket.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Re: 1910 rear strap
Post by Russ_Furstnow » Wed Aug 14, 2024 4:46 pm
The original saddle strap was made in two pieces that are riveted together. The buckle is a #56 buckle, not the #121 buckle that you show. I have attached a diagram that shows how the straps are rivited to the saddle. If you have any questions, just PM me. I hope this helps, Russ Furstnow
Rod
First Name: Rod
Last Name: Barrett
Re: 1910 rear strap
Post by Rod » Wed Aug 14, 2024 5:28 pm
It appears that I have the correct straps. What size are the rivets? Brass or steel.
Rod
First Name: Rod
Last Name: Barrett
Re: 1910 rear strap
Post by Rod » Wed Aug 14, 2024 5:32 pm
Are these the rivets? Cap in or out?
Rod
First Name: Rod
Last Name: Barrett
Re: 1910 rear strap
Post by Rod » Wed Aug 14, 2024 6:37 pm
Thank Russ. Done.
Re: 1910 rear strap
Post by Original Smith » Sat Aug 17, 2024 11:26 am
Excellent post! This is the kind of information that should be in the Vintage Ford, as opposed to the nonsense that is usually in there!
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Re: 1910 rear strap
Post by Herb Iffrig » Sat Aug 17, 2024 12:01 pm
Would this same arrangement be on my 1911 Torpedo? I think I bought the straps from one of the suppliers. I don't remember the separate pieces.
