1910 rear strap
Rod
Topic author - Posts: 97
- First Name: Rod
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
- Board Member Since: 2014
1910 rear strap
Does anyone have a picture of the rear strap? I had a new top installed but I’m having trouble with the rear strap. Here is a picture of what I came up with but I don’t think it’s correct. The saddle has a larger slot on one side and two round holes which I have no idea what they are for.
Re: 1910 rear strap
I believe you basically have the strap laced through correctly, however, the 2 small side holes are for rivets that hold the strap in place and also force the strap to lay all the way down in the bottom of the saddle.
Fire_chief
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
Re: 1910 rear strap
The original strap was made up of 3 pieces of leather, rivited together . The two shorter pieces were riveted to the two holes in the bracket.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Re: 1910 rear strap
The original saddle strap was made in two pieces that are riveted together. The buckle is a #56 buckle, not the #121 buckle that you show. I have attached a diagram that shows how the straps are rivited to the saddle. If you have any questions, just PM me. I hope this helps, Russ Furstnow
Rod
- First Name: Rod
Re: 1910 rear strap
It appears that I have the correct straps. What size are the rivets? Brass or steel.
Rod
- First Name: Rod
Rod
- First Name: Rod
Re: 1910 rear strap
Excellent post! This is the kind of information that should be in the Vintage Ford, as opposed to the nonsense that is usually in there!
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
Re: 1910 rear strap
Would this same arrangement be on my 1911 Torpedo? I think I bought the straps from one of the suppliers. I don't remember the separate pieces.
