WTB Drive Plate for 1925 Brake Drum With lugs
old_charley
First Name: Bryan
Last Name: Ostergren
* REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
Post by old_charley » Sun Jun 15, 2025 2:40 pm
I'm putting together a transmission and wishing to use a 1925 (narrow) brake drum with clutch disc lug shoes. I've found the bolt spacing for the drive plate is 1/8" less on this drum than earlier narrow brake drums. I'm in need of the drive plate/output shaft to mate with this drum. As accurately as I can measure, the bolt spacing 180 degrees across the drum is 6 11/16" on my '25 drum and 6 13/16" on the earlier ones. Any help will be greatly appreciated.
Thanks in advance.
Bryan Ostergren
eight one eight 321-5360
planetaryman at msn.com
AZTerry
First Name: Terry
Last Name: Loftus
* REQUIRED* Type and Year of Model Ts owned: 26 Speedster
Re: WTB Drive Plate for 1925 Brake Drum With lugs
Post by AZTerry » Sun Jun 15, 2025 3:13 pm
Hello Brian,
See attached service bulletin. You just need to modify your existing drive plate.
Terry
Transmission Drum Change.pdf
(120.78 KiB) Downloaded 88 times
Post by speedytinc » Sun Jun 15, 2025 4:10 pm
Terry is correct about modifying an early drive plate. Chances of finding the correct plate are slim & none.
Increase the counterbore for the bolt heads to get wrench/socket clearance also or use allen bolts.
The same bolt pattern modification can be done to use an early drive plate on a wide drum & carefully machining the O.D. also.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Sun Jun 15, 2025 5:51 pm
I can look thru my stash I may have one
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Sun Jun 15, 2025 5:58 pm
First one I grabbed measures 6 11/16 across the pattern
Post by speedytinc » Sun Jun 15, 2025 7:02 pm
Thats not what he is looking for. What you have is for a wide drum.
Put it on your narrow drum & notice the OD is too small. The OD should be the same as the drum band surface.
Post by Allan » Mon Jun 16, 2025 4:37 am
I might be just as easy to use a 26-7 wide brake drum and its matching drive plate. I believe there is no need for any modifications to run this combo in a three dip pan. You can't run a wide band on it though. However the narrow band will like the job because it gets to run on a single drum surface rather than the two piece drive surface provided by the narrow drum and its often mismatched OD on the drive plate.
Hope this helps Bryan.
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Mon Jun 16, 2025 8:21 am
I recently had the same issue on an engine I was building as a spare. I needed a good clutch/brake drum so I used one I’d been saving with the replaceable lugs. I wasn’t aware of the bulletin, but after assessing the surprising issue I milled out the inner side of the holes and it bolted up perfectly.
Last edited by Kenny Edmondson on Tue Jun 17, 2025 6:25 pm, edited 1 time in total.
old_charley
First Name: Bryan
Post by old_charley » Mon Jun 16, 2025 10:16 am
Thanks to all of you for your responses. I figured there was a "snowball's chance in hell" of finding one but it was worth a shot. I considered modifying the holes but questioned the wisdom of doing that. Glad to hear Ford recommended it and that it works. Karl, I appreciate you looking through your stash. Thanks again everyone.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Mon Jun 16, 2025 11:25 am
I have like 10 or 15 more I guess I misunderstood what the difference was I still may have one
