WTB Drive Plate for 1925 Brake Drum With lugs
Topic author - Posts: 219
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
I'm putting together a transmission and wishing to use a 1925 (narrow) brake drum with clutch disc lug shoes. I've found the bolt spacing for the drive plate is 1/8" less on this drum than earlier narrow brake drums. I'm in need of the drive plate/output shaft to mate with this drum. As accurately as I can measure, the bolt spacing 180 degrees across the drum is 6 11/16" on my '25 drum and 6 13/16" on the earlier ones. Any help will be greatly appreciated.
Thanks in advance.
Bryan Ostergren
eight one eight 321-5360
planetaryman at msn.com
Thanks in advance.
Bryan Ostergren
- First Name: Terry
- Last Name: Loftus
- * REQUIRED* Type and Year of Model Ts owned: 26 Speedster
Re: WTB Drive Plate for 1925 Brake Drum With lugs
Hello Brian,
See attached service bulletin. You just need to modify your existing drive plate.
Terry
Terry
- Attachments
- Transmission Drum Change.pdf
- (120.78 KiB) Downloaded 78 times
Terry is correct about modifying an early drive plate. Chances of finding the correct plate are slim & none.
Increase the counterbore for the bolt heads to get wrench/socket clearance also or use allen bolts.
The same bolt pattern modification can be done to use an early drive plate on a wide drum & carefully machining the O.D. also.
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
I can look thru my stash I may have one
- First Name: Karl
First one I grabbed measures 6 11/16 across the pattern
Thats not what he is looking for. What you have is for a wide drum.Karl Von Neumann wrote: ↑Sun Jun 15, 2025 5:58 pmFirst one I grabbed measures 6 11/16 across the pattern
Put it on your narrow drum & notice the OD is too small. The OD should be the same as the drum band surface.
I might be just as easy to use a 26-7 wide brake drum and its matching drive plate. I believe there is no need for any modifications to run this combo in a three dip pan. You can't run a wide band on it though. However the narrow band will like the job because it gets to run on a single drum surface rather than the two piece drive surface provided by the narrow drum and its often mismatched OD on the drive plate.
Hope this helps Bryan.
- First Name: Kenny
- Last Name: Edmondson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
I recently had the same issue on an engine I was building as a spare. I needed a good clutch/brake drum so I used one I’d been saving with the replaceable lugs. I wasn’t aware of the bulletin, but after assessing the surprising issue I milled out the inner side of the holes and it bolted up perfectly.
Last edited by Kenny Edmondson on Tue Jun 17, 2025 6:25 pm, edited 1 time in total.
- First Name: Bryan
Thanks to all of you for your responses. I figured there was a "snowball's chance in hell" of finding one but it was worth a shot. I considered modifying the holes but questioned the wisdom of doing that. Glad to hear Ford recommended it and that it works. Karl, I appreciate you looking through your stash. Thanks again everyone.
- First Name: Karl
I have like 10 or 15 more I guess I misunderstood what the difference was I still may have oneold_charley wrote: ↑Mon Jun 16, 2025 10:16 amThanks to all of you for your responses. I figured there was a "snowball's chance in hell" of finding one but it was worth a shot. I considered modifying the holes but questioned the wisdom of doing that. Glad to hear Ford recommended it and that it works. Karl, I appreciate you looking through your stash. Thanks again everyone.
