WTB: Mag drive for model t.
Topic author - Posts: 380
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Want a mag drive complete, don't need the mag. Let me know what you have, scammers need not waist the time, I will be asking for very detailed photos .
frontyboy
2h06-919-1949.(Seattle)
frontyboy
- First Name: Kevin
- Last Name: Pharis
- First Name: dick
- Last Name: dock
Re: WTB: Mag drive for model t.
cross drive non generator
thnx
frontyboy(my other speedster is a 1915 t roadster with a dual overhead cam GALLIVAN engine powered.
thnx
- First Name: Greg
- Last Name: Cunningham
- * REQUIRED* Type and Year of Model Ts owned: A single SCAT crankshaft
I wanna see that gallivan!!
- First Name: Kevin
- Last Name: Pharis
Sounds like yur lookin for a Matco or Columbo. None here, but I do have a couple extra 3in1 plates if you wanna run a dizzy
I have a Matco style that was made for both generator and non-generator engines. Have the cam gear but not the retaining nut. The teeth on both gears look ok. Some damage at the oil hole that had been repaired many years ago and a threaded brass extension installed. Think it was setup to use rubber hose as a connection. Might need to make new drive shaft if wanting to use impulse coupler. Will be asking $350 plus shipping. If interested send me a message to my email and I will get photos to you.
- First Name: DAN
- Last Name: MCEACHERN
Mark- I have the drive nuts for Matco crossdrives if you need one in the future.
Dan
Dan
