WTB: Mag drive for model t.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Fri Aug 22, 2025 6:09 pm
Want a mag drive complete, don't need the mag. Let me know what you have, scammers need not waist the time, I will be asking for very detailed photos .
frontyboy
2h06-919-1949.(Seattle)
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: WTB: Mag drive for model t.
Post by Kevin Pharis » Fri Aug 22, 2025 8:33 pm
Side drive…? Cross drive…? Generator motor…?
frontyboy
First Name: dick
Last Name: dock
Post by frontyboy » Fri Aug 22, 2025 10:17 pm
cross drive non generator
thnx
frontyboy(my other speedster is a 1915 t roadster with a dual overhead cam GALLIVAN engine powered.
GregC
First Name: Greg
Last Name: Cunningham
* REQUIRED* Type and Year of Model Ts owned: A single SCAT crankshaft
Post by GregC » Fri Aug 22, 2025 11:07 pm
I wanna see that gallivan!!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Aug 22, 2025 11:29 pm
Sounds like yur lookin for a Matco or Columbo. None here, but I do have a couple extra 3in1 plates if you wanna run a dizzy
Post by Mark Gregush » Sat Aug 23, 2025 12:56 pm
I have a Matco style that was made for both generator and non-generator engines. Have the cam gear but not the retaining nut. The teeth on both gears look ok. Some damage at the oil hole that had been repaired many years ago and a threaded brass extension installed. Think it was setup to use rubber hose as a connection. Might need to make new drive shaft if wanting to use impulse coupler. Will be asking $350 plus shipping. If interested send me a message to my email and I will get photos to you.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Aug 24, 2025 2:25 am
Mark- I have the drive nuts for Matco crossdrives if you need one in the future.
Dan
