Non Demountable Wheels on Late T's
Post by Original Smith » Wed Nov 19, 2025 5:36 pm
The inexpensive Ford models in the 1920's were sold without demountable wheels and starter and generators. How many of these exist today? An example is on the back cover of the current Model T Times. It has 30X3 non demountable wheels in front, and 30X3 1/2 non demountable wheels in the back. If you look closely through the rear spokes, I think I see a battery. So, it's possible a starter has been added. I saw a late T touring about 30 years ago like this. It would be nice if the owner can give us some information on this vehicle.
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Re: Non Demountable Wheels on Late T's
Post by Ed Baudoux » Wed Nov 19, 2025 8:00 pm
Maybe a dozen years ago, one of the T publications did a detailed article on a restored 27 non electric roadster.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Wed Nov 19, 2025 8:02 pm
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Thu Nov 20, 2025 10:06 am
Larry,
Why don't you reach out to the owners, Lee and Pam Doud, of Pine City NY, and ask them?
Keith
Post by Original Smith » Thu Nov 20, 2025 11:48 am
I assume the 1925 frames had the holes drilled for the battery carrier, so it would be easy to install one. However, two of the holes had the carrier riveted in, and the remaining hole was for the ground strap. from the factory.
Post by Original Smith » Thu Nov 20, 2025 5:15 pm
Someone mentioned top saddles. I believe Ford ceased putting top saddles on cars around 1922 or 23, and put hard rubber plugs in the holes. I assume by that time the majority of Ford owners didn't put their tops down much, and maybe that is why that happened, but the real reason, I believe, it enabled Ford to reduce the cost of the car. Of course, the owner could still buy those parts at the dealer.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Thu Nov 20, 2025 9:11 pm
Our 1923 touring, in the family since 1926, still had the plugs on the top saddle holes.
