Oil change ?
Larry e rutt
Last Name: Rutt
Oil change ?
Post by Larry e rutt » Wed Jul 31, 2019 5:38 pm
So put new oil in my T when I got it. I have driven it about 300 miles this summer and added 2 quarts through out the year , and my oil is dark with a brown color.. how many miles can you run till an oil change ? my question really is, do I need to change, or is dripping and adding enough to replenish ??
Bill Robinson
First Name: Bill
Last Name: Robinson
MTFCA Number: 22487
MTFCI Number: 17887
Re: Oil change ?
Post by Bill Robinson » Wed Jul 31, 2019 6:30 pm
It's time now.
Re: Oil change ?
Post by Scott_Conger » Wed Jul 31, 2019 6:50 pm
Agreed
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Re: Oil change ?
Post by D.Yoder » Wed Jul 31, 2019 7:16 pm
I change oil each spring. Just keep adding through the year :) :)
HalSched
First Name: Hal
Last Name: Schedler
MTFCA Number: 16688
MTFCI Number: 19356
Re: Oil change ?
Post by HalSched » Wed Jul 31, 2019 7:40 pm
Weak battery + hi amp starter= no juice for coils. Try cranking on BAT
Make sure the coils buzz... in the correct order... left lever up
Carb adj to 1 to 1/4. Gas in tank. :)
Last Name: VanOoteghem
Re: Oil change ?
Post by Jerry VanOoteghem » Wed Jul 31, 2019 8:17 pm
Me too. Except I don't drive anywhere NEAR the miles Dean does!
Last Name: Gregush
Re: Oil change ?
Post by Mark Gregush » Wed Jul 31, 2019 8:52 pm
Spring and fall oil changes. Summer weight and Winter weight.
1921 Huckster
Larry e rutt
Last Name: Rutt
Re: Oil change ?
Post by Larry e rutt » Thu Aug 01, 2019 5:28 pm
Ok... thanks. I think I'm going to drain the oil and slosh some kerosene around in there see if I can clean my motor out. Maybe the oil won't get dirty so fast..
Re: Oil change ?
Post by Scott_Conger » Thu Aug 01, 2019 5:50 pm
A far better plan would be to pull the bottom pan and go in and wipe everything down with shop rags. You will not believe the corruption that is laying on every horizontal surface. If your motor is an as-is motor, it undoubtedly has sharp carbon crusty material everywhere. I always clean out a T engine when I buy it or service one and this, I have found, is one of the best ways to ensure subsequent oil remains much MUCH cleaner. Kerosene will not do this for you.
Additionally, the kerosene "trick" dates back to the days when oils were crummy and the car/ engine was only a few years old. Some of these engines have run for many years, sat for many more and then run for still more years. That's a lot of crud which no slosh will remedy.
Larry e rutt
Last Name: Rutt
Re: Oil change ?
Post by Larry e rutt » Thu Aug 01, 2019 5:59 pm
Ok.. thanks...that makes sense.. that may have to wait for a winter project..but i would love to check out the inside..
Re: Oil change ?
Post by Scott_Conger » Thu Aug 01, 2019 6:08 pm
One more bit of advice: loosen pan and allow to tilt/hang from rearmost cap screw...drain for a day. Remove. Allow everything else to drip for a day.
THEN put on your least favorite shirt, go under, and start wiping. Be sure to take out the horseshoes and check all threads for good condition (the area under and behind these retainers will be among the filthiest areas you attack).
And of course...have FUN!
Last Name: House
MTFCA Number: 115
Re: Oil change ?
Post by George House » Thu Aug 01, 2019 6:29 pm
Wow! That’s a terrifically involved oil change Scott! I’ll bet the local oil change monkeys wouldn’t go for that. About the only extra effort I expend beyond taking out the 15/16” drain plug is jack up the front axle as far as my floor jack extends. Let it drip for a few hours. Royce learned me that several years ago...
“Fear is a Reaction...
Courage is a Decision”...Sir Winston Churchill
Re: Oil change ?
Post by Jerry VanOoteghem » Thu Aug 01, 2019 7:01 pm
Lots of well meaning overthinking here. First, by your description of the oil, "brown color," it's not even dirty yet, which makes sense at 300 miles. It's dirty when it's black. Second, you don't need to do anything other than just remove the drain plug, let it drain and drip for a while, replace the plug and put new oil in. Then, drive for a distance of your choosing, (I change at about 1000 miles), & repeat.
(True, that if the car is new to you, it's not a bad idea to have a "look see" inside the motor. Not just for cleanliness, but also any other potential gotchas in the future.)
Have fun!
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Oil change ?
Post by Erik Johnson » Thu Aug 01, 2019 7:13 pm
After an oil change, the oil in a Model T will quickly get dirty. I would go 1,000 miles before changing.
More importantly, I would figure out why you needed to add two quarts in only 300 miles. That's an awful lot of leaking and/or burning of oil.
Last Name: Gregush
Re: Oil change ?
Post by Mark Gregush » Thu Aug 01, 2019 8:07 pm
I too jack the front up and let it drain. While it is up I pour in anywhere from 1/2 to full qt fresh oil thru the oil filler spout and allow to flush the dippers trays. Does it help I don't know but makes me feel good. :lol:
1921 Huckster
Re: Oil change ?
Post by Scott_Conger » Thu Aug 01, 2019 8:45 pm
George
what I described is not an oil change. For old engines, it is a one-time cleaning of the crank case which will keep fresh oil from turning black again in 10 miles.
And it was suggested as an alternative to flushing with kerosene.
MTFCA Number: 16175
MTFCI Number: 14758
Re: Oil change ?
Post by Steve Jelf » Thu Aug 01, 2019 10:12 pm
It's also ungodly expensive. :D
Professor Fate
First Name: Danny
Last Name: S.
Re: Oil change ?
Post by Professor Fate » Thu Aug 01, 2019 10:49 pm
I run 10-30 and a quart of 30HD. the HD oil cleans well.
it gets dark quickly but seems to keep things reasonably clean. 500 miles, or when it gets real dark, or twice a year... whichever comes 1rst.....just sayin'...
MTFCA Number: 16175
MTFCI Number: 14758
Re: Oil change ?
Post by Steve Jelf » Thu Aug 01, 2019 11:57 pm
FWIW
From the Ford owner's manual: It is advisable to clean out the crank case by draining off the dirty oil when the new car has been driven three hundred and fifty miles; thereafter it will only be necessary to repeat this operation every seven hundred and fifty miles.
Re: Oil change ?
Post by Allan » Fri Aug 02, 2019 5:57 am
With an unknown car, I would closely follow Scott's proceedure. When I got Henrietta running, part of the recommissioning was an oil drain. The original stuff was like treacle. With fresh oil in, I ran her for 1/2 hour before draining the 'new' oil. You would not believe how filthy it was.
A month or two later, when I had to replace number one rod, the oil was dropped again, and was just as filthy. With the inspection pan off for the rod change, it was not difficult to find the source of the problem. The gap between the horse shoes and the pan sides was completely filled. Much of this was granular carbon like that found under piston crowns. With the horse shoes out the whole ugly mess was cleaned up, and I took the opportunity to wash down the insides of the pan as well.
Now I have resorted to checking the oil level, and will leave the present fill in place until we have done the September national tour.
FWIW,
Loftfield
First Name: Thomas
Last Name: Loftfield
MTFCA Number: 49876
MTFCI Number: 24725
Re: Oil change ?
Post by Loftfield » Fri Aug 02, 2019 7:42 am
Oil is cheap! The standard Model T has no oil pump and no filter other than an aftermarket sieve under the transmission inspection plate. Change oil often. I wouldn't hesitate to change after 300 miles, and certainly wouldn't go more than 500. My theory is to get any metal filings and band threads out BEFORE they cause trouble.I am only a caretaker for my antiques. Mine are all older than I am, and I intend them to outlive me to be passed on to the next caretaker, so I err on the side of caution and conservation.
Two quarts in 300 miles is WAY too much oil to have to add. You have either a serious leak, or the rings need a serious cleaning or major overhaul, or some combination of both. A leak will be obvious from the puddle on the floor, bad rings can be easily detected by the cloud of blue smoke billowing from the exhaust. Rings stuck from age or gunk can sometimes be cleaned and freed by adding ring cleaner directly into the spark plug holes, let it sit overnight. Marvel Mystery Oil, the source of much mirth and discussion on this forum, has never done anything bad to my engines, and may actually do a bit of good, I don't know, it did free up some stuck rings after sitting full strength in the cylinders overnight. We all hope your problems are simple fixes and not a major engine overhaul.
Larry e rutt
Last Name: Rutt
Re: Oil change ?
Post by Larry e rutt » Fri Aug 02, 2019 7:36 pm
My motor doesn't smoke at all... leaks a bit but not major..I dont know how many miles I drove I threw 300 out there but if I drove 15 times at 40 mile I guess that would be 6 hundred... I've been around vehicles and equipment i know would black dirty oil looks like.. my dad drove his 83 Chevy 6.2 liter diesel 30,000 between changes, and he got 280,000 before rebuilt.. but I never saw any oil get brown... ugh.. thanks for all the advice... I agree oil and grease are cheap, compared to the alternative...
Bill Robinson
First Name: Bill
Last Name: Robinson
MTFCA Number: 22487
MTFCI Number: 17887
Re: Oil change ?
Post by Bill Robinson » Fri Aug 02, 2019 8:31 pm
If this "brown" is not a translucent brown (NEW oil is a translucent brown, to my eyes, anyway) but instead the brown is a dirty, milky looking brown, then I would suspect water getting into the oil. Blown head gasket, cracked block, etc.
FordFool
First Name: Don
Last Name: Kirtley
MTFCA Number: 23703
MTFCI Number: 23153
Board Member Since: 2009
Re: Oil change ?
Post by FordFool » Fri Aug 02, 2019 8:33 pm
I don’t know about the rest of the guys out there but when I see brown oil I think of water??? Don
Re: Oil change ?
Post by Scott_Conger » Fri Aug 02, 2019 9:57 pm
There are no oil control rings in a T, and 2 quarts in 300 miles is not necessarily excessive, particularly if the T exhibits normal leaks. My dad's T used just under a quart of oil in a day's drive when on tour right after overhaul by reputable builder. 6,000 miles later, it still consumes or loses the same amount at the same rate. My old worn out '19 with cast iron pistons and clonking wrist-pins does almost exactly the same. Neither car smokes.
Brown oil is slightly dirty. Grey oil has water in it. Tan foamy oil at the breather/filler on a very cold day soon after start up is localized condensation in crankcase mixing with oil vapor and nothing to worry about so long as it eventually goes away with the engine warmed up.
Last Name: Gregush
Re: Oil change ?
Post by Mark Gregush » Fri Aug 02, 2019 10:44 pm
RE; " Tan foamy oil at the breather/filler on a very cold day soon after start up is localized condensation in crankcase mixing with oil vapor and nothing to worry about so long as it eventually goes away with the engine warmed up."
Some engines seem more prone to that ^, mine is one of them. I have spent a lot of time chasing that down to find out it was not a leak just my engine and where it is stored.
1921 Huckster
JP_noonan
Last Name: Noonan
Re: Oil change ?
Post by JP_noonan » Fri Aug 02, 2019 10:51 pm
Add me to the list of those here who think losing half your engine/trans total capacity in only 300 miles is excessive. :shock: Mine had some minor leaks at the usual places before i had it apart last time. when i put it back together i took some extra time to reduce the leaks, and now all i get is a little seep from the pan mount rivets. I check it often during the driving season which for me is only about a1000 miles a year, and i bet i only added less than a quart. Larry, have you checked to see if you're losing oil down the torque tube and into the rear diff?
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
kmatt
First Name: Kevin
Last Name: Matthiesen
MTFCA Number: 11598
Re: Oil change ?
Post by kmatt » Sat Aug 03, 2019 1:20 am
Larry: If your transmission doesn't have the plug in the tail shaft, as John has said, you may be loosing engine oil down the driveshaft tube. Check the rear axle oil level and if there is engine oil mixed with the heaver rear axle oil. By the way do you know anything about any work that has been done on you T's rear axle like bronze thrust washers ?
26troadster
Last Name: Lloid
Board Member Since: 2014
Re: Oil change ?
Post by 26troadster » Sun Aug 04, 2019 2:43 pm
I change them all in the fall and the spring. I use super tech (Walmart) oil year around. I know thats a hot topic but as long as its clean oil. IMO
