Magneto and coil testing unit
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Aug 18, 2019 2:15 pm
Just installed and adjusted all the magnets I cleaned and remagnetized from the coil testing machine I bought last week.
https://www.instagram.com/p/B1UJsS_A7X7 ... 1g1xqaw75e
Re: Magneto and coil testing unit
Post by Steve Jelf » Sun Aug 18, 2019 2:34 pm
Apparently you have to be an Instagram subscriber to see the video.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Aug 18, 2019 2:58 pm
Whoops, I’ll try You tube.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Aug 18, 2019 3:38 pm
Post by Steve Jelf » Sun Aug 18, 2019 3:51 pm
Yep, that works. If the magnets hold two pounds or more (I go for four) and the gap is .025"-.040" you're good to go.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Aug 18, 2019 3:59 pm
Yup, tested the weights with a 4 lb weight and the gap is around .025-28 so I’m set to test the amps / volts with separate test meters before checking the one on the unit.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Aug 18, 2019 6:23 pm
Here it is with an ammeter installed for testing.
https://m.youtube.com/watch?v=L5LL2iMca ... e=youtu.be
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Mon Aug 19, 2019 1:05 pm
The original Jewel ammeter had a sticky needle that wouldn’t return. I reset the pinion shaft and it works fine now.
https://m.youtube.com/watch?v=YVYxmrGGTqM
Post by Scott_Conger » Mon Aug 19, 2019 10:23 pm
Excellent!
good for you
