Magneto and coil testing unit
				Mark Osterman
- Last Name: Osterman
Just installed and adjusted all the magnets I cleaned and remagnetized from the coil testing machine I bought last week.
https://www.instagram.com/p/B1UJsS_A7X7 ... 1g1xqaw75e
Re: Magneto and coil testing unit
Apparently you have to be an Instagram subscriber to see the video.
				Mark Osterman
Whoops, I’ll try You tube.
				Mark Osterman
Yep, that works. If the magnets hold two pounds or more (I go for four) and the gap is .025"-.040" you're good to go.
				Mark Osterman
Yup, tested the weights with a 4 lb weight and the gap is around .025-28 so I’m set to test the amps / volts with separate test meters before checking the one on the unit.
				Mark Osterman
Here it is with an ammeter installed for testing.
https://m.youtube.com/watch?v=L5LL2iMca ... e=youtu.be
				Mark Osterman
The original Jewel ammeter had a sticky needle that wouldn’t return. I reset the pinion shaft and it works fine now.
https://m.youtube.com/watch?v=YVYxmrGGTqM
Excellent!
good for you
									good for you
