Front Plate Oil Pump ID
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Sun Sep 15, 2019 7:50 pm
Can anyone identify this oil pump? Thanks
Les Schubert
First Name: Les
Last Name: Schubert
Re: Front Plate Oil Pump ID
Post by Les Schubert » Sun Sep 15, 2019 8:39 pm
Really cute!!
I wonder if it is a “vane style “
Great find
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Sep 15, 2019 8:40 pm
I have a generator that would work good with it as it has a distributor on the back of it
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Mon Sep 16, 2019 10:53 am
Les:
the pump looks very much like the pump on my Dodge Brothers … a similar pump was used on Dodge Bro. engines from 1914 thru the 4 cyl. era … it appears to be bolted to a plate that is attached to the Ford front timing cover … the DB pump came in a 2 or 3 bolt mounting depending on year and engine series and was a vane type pump ...always an optimist...Gene French
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Sep 16, 2019 3:07 pm
Gene
Thank you for the information
All the best
