Phone Apps: Interesting test tools - tachometer, strobe light, rpm, speedometer, elevation, etc
AdminJeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by AdminJeff » Sat Jan 04, 2020 12:52 pm
I thought I'd share a recent discovery I haven't seen mentioned here. Strobe lights that measure rpm have been around for decades. Good ones with digital readouts are expensive. Here's a way to get one for free using your smartphone to Measure the RPM of your motor, your wheels, your water pump, lathe, whatever!
Search for the app StrobeLight tachometer app on the iPhone or Android. It uses the pic flash led on the iPhone for the strobe light. Paint a white line on any shaft, start the app, point your phone at the shaft and you have the perfect instrument for measuring rpm of anything that spins! This is how I set up generator third brushes to put out the right current. The engineer in me likes to measure everything!
Press the button on the upper right to turn on/off the strobe. Then you have start with an approximate rpm and then adjust the app rpm setting using the +/- buttons until the white line doesn't "move" while the shaft is spinning. I found that dimming the lights depending on what you're measuring might help a bit at first. This gets the app and the shaft "in sync" and gives you a true reading of the actual rpm. Easy once you get the hang of it.
Jeff
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Interesting test tool - tachometer, strobe light, rpm measurement
Post by BE_ZERO_BE » Sat Jan 04, 2020 3:42 pm
Very interesting - Thanks Jeff.
Respectfully Submitted,
Be_Zero_Be
Heck914
First Name: MARK
Last Name: HAECKEL
* REQUIRED* Type and Year of Model Ts owned: 1927
Post by Heck914 » Sat Jan 04, 2020 6:23 pm
Wow, that works good! Thank for you posting , never knew about this . I have an old milling machine (converted to variable DC motor) and a old small Atlas lathe in the garage. Now i can verify the speeds !
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Jan 04, 2020 6:46 pm
Thanks for sharing Jeff. All the goodies on your phone will blow you away.
Hank
donald4ham
First Name: Donald
Last Name: Goodwin
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
Post by donald4ham » Sat Jan 04, 2020 6:55 pm
This app will come in very handy, thanks for finding this.
AdminJeff
Post by AdminJeff » Sun Jan 05, 2020 7:46 am
I just realized that you guys probably have not have discovered the true power of what's sitting in all your pockets. I was an early investor in GPS and Bluetooth chips that are in all your phones now, and I'm friends with the guy at HP who literally invented the GPS, so I take a lot of this stuff for granted. But I'll bet it's new to the vast majority of all of you. If needed, we can take this off topic, but it's really not. Read on.
The apps in your phones are really powerful. Start simple - There's a level app and after a lot of trial and error I finally found a decent magnometer app that's pretty accurate. Great for testing field coils on starters and generators.
Here are Other free apps I find very useful in this T hobby and I use a lot - these are the actual app names to search for in the Apple App Store. Not sure on Android but there should be equalivants, if not the exact same app:
Bubble Level - cool on many levels (!), swipe left or right for each app
Elevation - see how high you've climbed in your T. My hill is almost an 800' rise. Now you can see why I've burned so much Babbitt out of #1 rods driving up my hill day after day. But not anymore thanks to Hank's ultra cool Mountain Pan I just installed!
Speedometer - see how accurate your T Speedo is or how fast Brad Lusk's "stock" car really goes. (We hit 56mph and it was scary). This is a really great Touring app, even keeps track of where you went. Swipe to see all the screens. Hit the options button (always a gear icon) to set things up, then hit the record button to record your tracks while you drive.
It's boring until you start moving but it's 4am and I'm still in bed :geek:
Don't forget to "swipe" the screen to the left or right on apps to see other functions. Take your finger and press lightly on the left or right side of your phone screen and swipe the other way. You will be literally amazed at what these apps are capable of.
Precision? Are these precise? I can assure you that these apps are high quality and extremely accurate. I know the technology firsthand that sits in your phones. It's nothing short of amazing. An app is just a program that accesses data from the components in the phone and displays it in a useful way.
If you don't know how to get apps installed on your phone, go for a drive to any kindergarten school and find the first kid you see. Ask them and they will show you how. Or ask your grand kids. Or that totally clueless clerk at Walmart. They might not know how to work at Walmart but they know how to install apps. Trust me on this...
These remaining screenshots are all from one app- Bubble Level. Swipe the screen to see the next component in action.
AdminJeff
(Yes, I'm an app geek/freak)
Last Name: Hjortnaes
Re: Phone Apps: Interesting test tools - tachometer, strobe light, rpm, speedometer, elevation, etc
Post by DHort » Sun Jan 05, 2020 1:49 pm
I found 27 speedometer apps on my droid and that is just the first search. Which one do I use?
Emeraude
Last Name: Loranger
* REQUIRED* Type and Year of Model Ts owned: 1921 touring
Post by Emeraude » Sun Jan 05, 2020 2:31 pm
Will this app work on a I pad? I don,t have a iPhone.
AdminJeff
Post by AdminJeff » Sun Jan 05, 2020 3:13 pm
David,
look at the pics and see if you can find one that looks like what I posted. Or just try one that has good ratings.
GEorge,
yes, they will all work on an ipad, however, not all apps rwill work holding the ipad sideways because they were made for an iphone. But, the ones I listed all do.
Jeff
Post by DHort » Sun Jan 05, 2020 6:55 pm
Hey Jeff,
The apps do have names under them - must be author. You said yours has a trip recorder and that is what I would like to have. Speed is secondary. If and when you have time, maybe you can find that info. Thank you.
AdminJeff
Post by AdminJeff » Mon Jan 06, 2020 8:17 am
Hey Jeff,
Here's the "speedometer Simple"app written by Mikrasya. Search by author or by app name. I went for a drive yesterday and turned on trip record.
Clicking on the gear icon and the trip history gives you this:
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Jan 06, 2020 1:36 pm
I tried one of these strobe light tachometers once and was disappointed at the performance. Who is the developer of the app you are using? I could not find one with a screen like yours. I assume it is for I-Phone only with no Android version.
AdminJeff
Post by AdminJeff » Mon Jan 06, 2020 2:23 pm
They are by no means perfect, that's for sure. The one I have is by Dmitriy Kharutskiy - unsure of Android. They work about like this:
• Up to 100 Hz (6000 RPM) for the iPhone flashlight (iOS < 9).
• Up to 40 Hz (2500 RPM) for the iPhone flashlight (iOS 9+).
To change the frequency, you should simply press and hold the button. The flicker frequency can be displayed either in Hz or RPM.
The image you see will be sharper in lower external light.
After a long period of usage, in case of overheating, the iPhone flashlight turns off automatically.
Post by DHort » Mon Jan 06, 2020 2:56 pm
Apparently not written for a droid. Bummer.
andywilson
First Name: Andy
Last Name: Wilson
Post by andywilson » Wed Oct 14, 2020 10:05 am
Search for the app StrobeLight tachometer app on the iPhone or Android. It uses the pic flash led on the iPhone for the strobe light. Paint a white line on any shaft, start the apphttps://gbapps.net/fmwhatsapp-apk-download/, point your phone at the shaft and you have the perfect instrument for measuring rpm of anything that spins! This is how I set up generator third brushes to put out the right current. The engineer in me likes to measure everything!
Jeff
thank you for sharing this app jeff you have found an amazing and very interesting App.
DLodge
First Name: Dick
Last Name: Lodge
Post by DLodge » Wed Oct 14, 2020 10:19 am
... If needed, we can take this off topic, but it's really not.
Aha! "Admin Jeff meets Frustrating Forum Features." Not a problem for me, since I have learned to check the Off-Topic Section at least once a day, but I did prefer the "OT" designation used in the subject line on the main forum.
That said, there is a lot of very cool stuff in this thread. I will definitely be passing it on. You must be some kind of a techy guy, Jeff. :D
Andrew125
First Name: Andrew
Last Name: Johnson
Post by Andrew125 » Sat Jan 22, 2022 8:17 am
Nulls Brawl Apk
Jeff
I don't know much about other test tools, but I know about tachometer and elevation.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Jan 24, 2022 11:46 am
Thank you Jeff, I like this kind of tools. I will try for sure
Super Mario Bross ;)
1911 Touring
1914 Speedster
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Mon Jan 24, 2022 5:30 pm
AdminJeff: how do we find these cool apps? Specifically, I what do we type in?
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Thu Jan 27, 2022 10:46 pm
Marty, turn on your phone and sign in.
Look on your screens for a file app called AppStore
AppStore
AppStore
Touch AppStore
You will get something like this:
Search
Search
Type in what you are looking for such as “tachometer” or “speedometer”
Then touch search
Tachometer
Tachometer
Choose the app you want to try. I prefer free as you can delete with no fuss if it’s not what you want.
The app will come up and you go thru a password process and hey presto you have the app.
Tony Bowker
La Mesa, California
Post by DHort » Fri Jan 28, 2022 1:26 am
If he has a droid he will never find AppStore. Then it is called Play Store.
Many apps do not work on both types of phones, so it is hard to find the
same one. AdminJeff uses an iPhone.
StrobeLight tachometer does not show up in Play Store.
redrichard
First Name: Red
Last Name: Richard
Post by redrichard » Thu Apr 28, 2022 7:15 am
If he has a droid he will never find AppStore. Then it is called Play Store. aeroinsta apk download
Many mini militia apk apps do not work on both types of phones, so it is hard to find the
What is the best alternative if this test app doesn't work with Android 10?
Rupesh
First Name: Rupesh
Last Name: Verma
Post by Rupesh » Tue Feb 07, 2023 9:40 am
Vanced Manager
Yeah. i searched for it but no luck. that's only for iOS.
Naveen
First Name: Naveen
Last Name: sHARMA
Post by Naveen » Tue Feb 07, 2023 9:45 am
David,
Null’s Clash
Even apps with good ratings on Android are no better.
JohnSuar
Last Name: Suarez
Post by JohnSuar » Fri Aug 23, 2024 3:36 pm
Elevation - see how high you've climbed in your T. My hill is almost an 800' rise. Now you can see why I've burned so much Babbitt out of #1 rods driving up my hill day after day. But not anymore thanks to Hank's ultra cool Mountain Pan I just installed! I recently realized that I haven't looked at the apps that have appeared in the ep store for half a year. I want to say that I was surprised when I went there. A lot of cool stuff appeared for both iPhone and MacBook. I also read about how to read script while looking into camera, I learned everything https://setapp.com/how-to/read-script-w ... nto-camera here. This is exactly what I need. In short, innovations and technologies are moving forward.
AdminJeff
Really cool, I didn’t know about this, I’ll try it in practice.
trossard
First Name: Leonardo
Last Name: Trossard
* REQUIRED* Type and Year of Model Ts owned: Ford Model T, Year: 1927
Post by trossard » Fri Jun 06, 2025 12:12 pm
Jeff
Smart idea, using your phone as a strobe tachometer, way cheaper than buying one! It’s like Nulls Brawl APK, giving players more freedom without the usual limits.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Jun 06, 2025 4:19 pm
Watch these Apps I had a tach App on my iPhone & it worked real good. Some time later when I tried to show it to a friend it asked for a $9.98 per month subscription to continue!
Rupesh
First Name: Rupesh
Last Name: Verma
Post by Rupesh » Wed Sep 17, 2025 9:42 am
Jeff, you mentioned being an early investor in GPS and Bluetooth chips. Could you elaborate on the difference between consumer-grade phone sensors and professional-grade tools? How accurate can we reasonably expect these phone apps to be for serious work versus just for fun?Нуллс Бравл
