Phone Apps: Interesting test tools - tachometer, strobe light, rpm, speedometer, elevation, etc
Topic author - Posts: 1109
- Last Name: Stevenson
I thought I'd share a recent discovery I haven't seen mentioned here. Strobe lights that measure rpm have been around for decades. Good ones with digital readouts are expensive. Here's a way to get one for free using your smartphone to Measure the RPM of your motor, your wheels, your water pump, lathe, whatever!
Search for the app StrobeLight tachometer app on the iPhone or Android. It uses the pic flash led on the iPhone for the strobe light. Paint a white line on any shaft, start the app, point your phone at the shaft and you have the perfect instrument for measuring rpm of anything that spins! This is how I set up generator third brushes to put out the right current. The engineer in me likes to measure everything!
Press the button on the upper right to turn on/off the strobe. Then you have start with an approximate rpm and then adjust the app rpm setting using the +/- buttons until the white line doesn't "move" while the shaft is spinning. I found that dimming the lights depending on what you're measuring might help a bit at first. This gets the app and the shaft "in sync" and gives you a true reading of the actual rpm. Easy once you get the hang of it.
Jeff
Jeff
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
- First Name: BOB
- Last Name: CASCISA
Re: Interesting test tool - tachometer, strobe light, rpm measurement
Very interesting - Thanks Jeff.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: MARK
- Last Name: HAECKEL
- * REQUIRED* Type and Year of Model Ts owned: 1927
Wow, that works good! Thank for you posting , never knew about this . I have an old milling machine (converted to variable DC motor) and a old small Atlas lathe in the garage. Now i can verify the speeds !
- First Name: Henry
- Last Name: Lee
Thanks for sharing Jeff. All the goodies on your phone will blow you away.
Hank
Hank
- First Name: Donald
- Last Name: Goodwin
This app will come in very handy, thanks for finding this.
I just realized that you guys probably have not have discovered the true power of what's sitting in all your pockets. I was an early investor in GPS and Bluetooth chips that are in all your phones now, and I'm friends with the guy at HP who literally invented the GPS, so I take a lot of this stuff for granted. But I'll bet it's new to the vast majority of all of you. If needed, we can take this off topic, but it's really not. Read on.
The apps in your phones are really powerful. Start simple - There's a level app and after a lot of trial and error I finally found a decent magnometer app that's pretty accurate. Great for testing field coils on starters and generators.
Here are Other free apps I find very useful in this T hobby and I use a lot - these are the actual app names to search for in the Apple App Store. Not sure on Android but there should be equalivants, if not the exact same app:
Bubble Level - cool on many levels (!), swipe left or right for each app
Elevation - see how high you've climbed in your T. My hill is almost an 800' rise. Now you can see why I've burned so much Babbitt out of #1 rods driving up my hill day after day. But not anymore thanks to Hank's ultra cool Mountain Pan I just installed!
Speedometer - see how accurate your T Speedo is or how fast Brad Lusk's "stock" car really goes. (We hit 56mph and it was scary). This is a really great Touring app, even keeps track of where you went. Swipe to see all the screens. Hit the options button (always a gear icon) to set things up, then hit the record button to record your tracks while you drive.
It's boring until you start moving but it's 4am and I'm still in bed
Don't forget to "swipe" the screen to the left or right on apps to see other functions. Take your finger and press lightly on the left or right side of your phone screen and swipe the other way. You will be literally amazed at what these apps are capable of.
Precision? Are these precise? I can assure you that these apps are high quality and extremely accurate. I know the technology firsthand that sits in your phones. It's nothing short of amazing. An app is just a program that accesses data from the components in the phone and displays it in a useful way.
If you don't know how to get apps installed on your phone, go for a drive to any kindergarten school and find the first kid you see. Ask them and they will show you how. Or ask your grand kids. Or that totally clueless clerk at Walmart. They might not know how to work at Walmart but they know how to install apps. Trust me on this...
These remaining screenshots are all from one app- Bubble Level. Swipe the screen to see the next component in action.
AdminJeff
(Yes, I'm an app geek/freak)
AdminJeff
- Last Name: Hjortnaes
Re: Phone Apps: Interesting test tools - tachometer, strobe light, rpm, speedometer, elevation, etc
I found 27 speedometer apps on my droid and that is just the first search. Which one do I use?
- Last Name: Loranger
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring
Will this app work on a I pad? I don,t have a iPhone.
David,
look at the pics and see if you can find one that looks like what I posted. Or just try one that has good ratings.
GEorge,
yes, they will all work on an ipad, however, not all apps rwill work holding the ipad sideways because they were made for an iphone. But, the ones I listed all do.
Jeff
GEorge,
Jeff
Hey Jeff,
The apps do have names under them - must be author. You said yours has a trip recorder and that is what I would like to have. Speed is secondary. If and when you have time, maybe you can find that info. Thank you.
Here's the "speedometer Simple"app written by Mikrasya. Search by author or by app name. I went for a drive yesterday and turned on trip record. Clicking on the gear icon and the trip history gives you this:
- Last Name: Nunn
I tried one of these strobe light tachometers once and was disappointed at the performance. Who is the developer of the app you are using? I could not find one with a screen like yours. I assume it is for I-Phone only with no Android version.
They are by no means perfect, that's for sure. The one I have is by Dmitriy Kharutskiy - unsure of Android. They work about like this:
• Up to 100 Hz (6000 RPM) for the iPhone flashlight (iOS < 9).
• Up to 40 Hz (2500 RPM) for the iPhone flashlight (iOS 9+).
To change the frequency, you should simply press and hold the button. The flicker frequency can be displayed either in Hz or RPM.
The image you see will be sharper in lower external light.
After a long period of usage, in case of overheating, the iPhone flashlight turns off automatically.
Apparently not written for a droid. Bummer.
- First Name: Andy
- Last Name: Wilson
thank you for sharing this app jeff you have found an amazing and very interesting App.AdminJeff wrote: ↑Sat Jan 04, 2020 12:52 pmI thought I'd share a recent discovery I haven't seen mentioned here. Strobe lights that measure rpm have been around for decades. Good ones with digital readouts are expensive. Here's a way to get one for free using your smartphone to Measure the RPM of your motor, your wheels, your water pump, lathe, whatever!
Search for the app StrobeLight tachometer app on the iPhone or Android. It uses the pic flash led on the iPhone for the strobe light. Paint a white line on any shaft, start the apphttps://gbapps.net/fmwhatsapp-apk-download/, point your phone at the shaft and you have the perfect instrument for measuring rpm of anything that spins! This is how I set up generator third brushes to put out the right current. The engineer in me likes to measure everything!
Jeff
- First Name: Dick
- Last Name: Lodge
Aha! "Admin Jeff meets Frustrating Forum Features." Not a problem for me, since I have learned to check the Off-Topic Section at least once a day, but I did prefer the "OT" designation used in the subject line on the main forum.
That said, there is a lot of very cool stuff in this thread. I will definitely be passing it on. You must be some kind of a techy guy, Jeff.
- First Name: Andrew
- Last Name: Johnson
I don't know much about other test tools, but I know about tachometer and elevation.AdminJeff wrote: ↑Sat Jan 04, 2020 12:52 pmI thought I'd share a recent discovery I haven't seen mentioned here. Strobe lights that measure rpm have been around for decades. Good ones with digital readouts are expensive. Here's a way to get one for free using your smartphone to Measure the RPM of your motor, your wheels, your water pump, lathe, whatever!
Nulls Brawl Apk
Jeff
- First Name: Mario
- Last Name: Brossard
Thank you Jeff, I like this kind of tools. I will try for sureAdminJeff wrote: ↑Mon Jan 06, 2020 2:23 pmThey are by no means perfect, that's for sure. The one I have is by Dmitriy Kharutskiy - unsure of Android. They work about like this:
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Marty
- Last Name: Bufalini
AdminJeff: how do we find these cool apps? Specifically, I what do we type in?
- First Name: Tony
- Last Name: Bowker
Marty, turn on your phone and sign in.
Look on your screens for a file app called AppStore
Touch AppStore
You will get something like this:
Type in what you are looking for such as “tachometer” or “speedometer”
Then touch search
Choose the app you want to try. I prefer free as you can delete with no fuss if it’s not what you want.
The app will come up and you go thru a password process and hey presto you have the app.
Touch AppStore
Then touch search
Tony Bowker
La Mesa, California
La Mesa, California
If he has a droid he will never find AppStore. Then it is called Play Store.
Many apps do not work on both types of phones, so it is hard to find the
same one. AdminJeff uses an iPhone.
StrobeLight tachometer does not show up in Play Store.
- First Name: Red
- Last Name: Richard
What is the best alternative if this test app doesn't work with Android 10?DHort wrote: ↑Fri Jan 28, 2022 1:26 amIf he has a droid he will never find AppStore. Then it is called Play Store. aeroinsta apk download
Many mini militia apk apps do not work on both types of phones, so it is hard to find the
- First Name: Rupesh
- Last Name: Verma
Yeah. i searched for it but no luck. that's only for iOS.DHort wrote: ↑Fri Jan 28, 2022 1:26 amIf he has a droid he will never find AppStore. Then it is called Play Store.
Vanced Manager
- First Name: Naveen
- Last Name: sHARMA
Even apps with good ratings on Android are no better.AdminJeff wrote: ↑Sun Jan 05, 2020 3:13 pmDavid,
Null’s Clash
- Last Name: Suarez
Really cool, I didn’t know about this, I’ll try it in practice.AdminJeff wrote: ↑Sun Jan 05, 2020 7:46 amI just realized that you guys probably have not have discovered the true power of what's sitting in all your pockets. I was an early investor in GPS and Bluetooth chips that are in all your phones now, and I'm friends with the guy at HP who literally invented the GPS, so I take a lot of this stuff for granted. But I'll bet it's new to the vast majority of all of you. If needed, we can take this off topic, but it's really not. Read on.
Elevation - see how high you've climbed in your T. My hill is almost an 800' rise. Now you can see why I've burned so much Babbitt out of #1 rods driving up my hill day after day. But not anymore thanks to Hank's ultra cool Mountain Pan I just installed! I recently realized that I haven't looked at the apps that have appeared in the ep store for half a year. I want to say that I was surprised when I went there. A lot of cool stuff appeared for both iPhone and MacBook. I also read about how to read script while looking into camera, I learned everything https://setapp.com/how-to/read-script-w ... nto-camera here. This is exactly what I need. In short, innovations and technologies are moving forward.
AdminJeff
- First Name: Leonardo
- Last Name: Trossard
- * REQUIRED* Type and Year of Model Ts owned: Ford Model T, Year: 1927
Smart idea, using your phone as a strobe tachometer, way cheaper than buying one! It’s like Nulls Brawl APK, giving players more freedom without the usual limits.AdminJeff wrote: ↑Sat Jan 04, 2020 12:52 pmI thought I'd share a recent discovery I haven't seen mentioned here. Strobe lights that measure rpm have been around for decades. Good ones with digital readouts are expensive. Here's a way to get one for free using your smartphone to Measure the RPM of your motor, your wheels, your water pump, lathe, whatever!
Jeff
- First Name: craig
- Last Name: leach
Watch these Apps I had a tach App on my iPhone & it worked real good. Some time later when I tried to show it to a friend it asked for a $9.98 per month subscription to continue!
- Last Name: Verma
Jeff, you mentioned being an early investor in GPS and Bluetooth chips. Could you elaborate on the difference between consumer-grade phone sensors and professional-grade tools? How accurate can we reasonably expect these phone apps to be for serious work versus just for fun?Нуллс Бравл
