carbide generator hose
Post by Original Smith » Tue Apr 28, 2020 11:51 am
Does anyone have the correct factory data on the correct length of the hose for a '13-14 ? Earlier models are different. Next, the hose Ron Gocek supplied in his kits were apparently long enough for 1912 on back, but not for a '13-'14. It's too bad he doesn't supply the correct hose any more. The last run he had made was too big an O.D., and will not fit through the hole in the splash shield or the radiator holes! So much for research!
rnwilliams
First Name: Ricky
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 12 Com. Rdstr, 12 Delivery, 2-12 Tou, 15 Tou, 21 Cpe, 25 Cpe 25 TT, 26 TT, 27TT, 26 PU, 26 Tou, 2-26 4dr, 26 Del, 27 4dr
Re: carbide generator hose
Post by rnwilliams » Tue Apr 28, 2020 12:26 pm
I sure need some hose that is correct too if you find something. What are others using?
Richard Williams, Humboldt, TN
President, Tennessee T's inc.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Apr 28, 2020 2:21 pm
Either me need the correct hose for a '13-14, I'm in if you find something somewhere.
Super Mario Bross ;)
1911 Touring
1914 Speedster
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Apr 28, 2020 2:51 pm
Please provide the ID and OD dimensions.
Hank
Post by Original Smith » Wed Apr 29, 2020 10:50 am
According to what I've heard, the original O.D. on that hose is 7/16" However 1/2" will work. I don't know if it is still being made, but I just found a length of air compressor hose in my garage that is probably at least 50 years old, and is 1/2" O.D. It is red, and has the exact same look that we are all after, and is 1/4" I.D. too! McMaster Carr has all kinds of red hose that fits, and is red too, but one would have to be able to go to their warehouse to look at all the samples they have to see for yourself.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Apr 29, 2020 12:33 pm
I got some hose from snyders about 2 years ago that fit fine thru the hole in the apron of my fairly original’13 touring.
Post by RajoRacer » Wed Apr 29, 2020 1:46 pm
I received a length of red tubing from my T buddy in Canada - I'll measure it up, Larry.
Post by Original Smith » Fri May 01, 2020 11:34 am
Steve: Let me know what you find out! The air compressor hose I found looks right, and fits through the radiator side panels, but I can't force it through the hole in the splash shield. Even though the hose is still flexible it won't go through. Even though most people would never know, I hate to enlarge the hole in the splash shield to accommodate that hose! What I'd like to see is for Ron Gocek to start offering the correct hose again like he did years ago. 7/16 OD, and 1/4 ID.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Fri May 01, 2020 11:45 am
I got red rubber tubing from Lang’s just a couple of years ago that measured up correctly. It had a sort of “fabric weave” light texture. My Lizzie spends summers outside, and the UV has not been kind to these hoses. It’s checking and fading some, though still viable. At one point I thought I read the original stuff was ribbed. Is that correct ? What kind of longevity was normal for the tubing “in the day” ?
I had the impression what I got was made for Bunsen burners in lab situations, so no worries about sunlight deterioration in that application.
"Get a horse !"
Kbillet
First Name: Keith
Last Name: Billet
Post by Kbillet » Wed May 06, 2020 5:13 pm
Horrible Freight sells red airline hose. 5' for $5.69. It's their item # 98944. 1/4 inch ID. and 1/2" OD. You can remove the ink lettering with acetone. The package is called Swivel Whip Hose. Used it on my Torpedo and it looks great.
rnwilliams
First Name: Ricky
Last Name: Williams
Post by rnwilliams » Wed May 06, 2020 8:33 pm
I bought some of the red hose, y'all suggested, from Harbor Freight yesterday. Looks good to me and the printed letters came right off.
