Size of bore in cam bearings holes in block??
Last Name: Hatch
Post by Dan Hatch » Tue Dec 14, 2021 1:38 pm
Does anyone have the size for the front and center cam bearings holes in block?
Have not looked for it but was hoping someone had the Ford block drawing.
Another question, any idea why the cam bearings are not made in the oversized OD for worn block holes? At one time they were and that solved a lot of problems.
Who makes them now? I would be willing to buy a batch of front oversized. If they are on here please contact me at email address in pictures. Thanks Dan
Last Name: van Ekeren
Re: Size of bore in cam bearings holes in block??
Post by Kerry » Tue Dec 14, 2021 3:22 pm
Can't help with drawing specs but I know that the OD of the bearing is 1.371 and measuring a few blocks, they came in at 1.375. 1-3/8"
Last Name: Hatch
Post by Dan Hatch » Wed Dec 15, 2021 2:07 pm
I found a post of 1.371 to 1.373. If the is correct, 1.375 is worn.
That is why we need oversized cam bearings.
Thanks Dan
Post by Kerry » Wed Dec 15, 2021 2:46 pm
If so Dan I find that interesting, anything usually on Fords basic machining was in whole fractions. The moving and replaceable parts had the clearances.
Post by TXGOAT2 » Wed Dec 15, 2021 2:50 pm
Can you lightly knurl the OD of replacement bearings to get a good fit?
Post by Kerry » Wed Dec 15, 2021 3:05 pm
Pat, the bearing case is cast iron, I don't think knurling would work.
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Dec 15, 2021 3:46 pm
I've knurled them before.
Post by Jerry VanOoteghem » Wed Dec 15, 2021 3:49 pm
Additionally, the bearings are split, so holding onto them in order to knurl them is a bit more difficult... but not impossible I suppose.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Dec 15, 2021 4:50 pm
Shim stock!!!!!
Post by Kerry » Wed Dec 15, 2021 5:28 pm
Henry, I pulled down an engine looking for a knock, turned out to be the cam bearings had been shimmed up with stock and had been flogged out over miles and time.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Dec 15, 2021 6:28 pm
You have to use tempered shim stock, should have mentioned that.., Oops!
Last Name: Hatch
Post by Dan Hatch » Wed Dec 15, 2021 6:31 pm
What we need are Oversized bearings. The front one is the one usually worn.
The person that use to make did that, but quit a few years ago.
Who is making these new bearings? Someone has to know them.
Post by Kerry » Wed Dec 15, 2021 7:54 pm
There are other options, make your own or turn down the cast iron on an original and sleeve it.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Dec 15, 2021 8:00 pm
Like your option Frank!!!!!!!
