Exhaust manifold question
Boaski
First Name: Todd
Last Name: Retterer
Post by Boaski » Mon Sep 11, 2023 9:28 pm
My T has an exhaust manifold that appears to be for an auxiliary heater:
The shroud is missing and there are no holes in the floor to duct the heat if the shroud was there. My question is: are there any advantages or disadvantages of running this exhaust manifold? I know it seems to radiate heat rather well under the hood.
Last Name: Tannehill
Re: Exhaust manifold question
Post by JTT3 » Mon Sep 11, 2023 9:45 pm
One aff do vantage is you can easily build the cover to make it work for winter driving
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Post by Jim, Sr. » Mon Sep 11, 2023 10:13 pm
The heater manifolds are usually pretty straight, and do not warp like the standard manifold.
1922 Coupe , 1926 Touring
Post by TRDxB2 » Mon Sep 11, 2023 11:14 pm
Like he said, they don't warp- big advantage
Heater shroud
Post by Jerry VanOoteghem » Tue Sep 12, 2023 6:33 am
It may lend itself well to a custom-made manifold cooker.
Boaski
First Name: Todd
Last Name: Retterer
Post by Boaski » Wed Sep 13, 2023 9:38 pm
Thanks for the responses. I guess I'll keep it on there if the stock ones are more prone to warping. Does the little "A" cast into the manifold mean it' an Arvin?
I noticed my intake was a little frosty looking on hot, high humidity days. I think I'll have to rig up an inlet pipe somehow.
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Post by GG Gregory » Wed Sep 13, 2023 9:56 pm
Have one like it on my 27 Roadster, and a good spare if I ever need it !
1922ford
Last Name: Bauer
* REQUIRED* Type and Year of Model Ts owned: 1922 touring 1924 roadster 1925 coupe
Board Member Since: 2012
Post by 1922ford » Fri Sep 15, 2023 9:38 am
Our ’22 touring has the same exhaust manifold as yours has. The comments are correct about it being unlikely to warp. It’s a good unit to have.
The carb and intake manifold on the touring routinely iced up from moderately to seriously. There seems to be no heat pipe (or stove) available for the exhaust manifolds we have, so I cobbled one up using an old heat pipe that had seen its better days. As you can see I also incorporated the lid off of a metal can. It was a cut, fit, and try job. It isn’t pretty but has been on the job since 1999.
I hope the photo show how I fashioned a heat pipe and if you have any questions I’d be glad to try and answer them.
Good luck. Tom in Taylor Mill, KY 41015
Boaski
First Name: Todd
Last Name: Retterer
Post by Boaski » Fri Sep 15, 2023 8:47 pm
Thanks for posting the picture. That gives me an idea of what to make.
Post by TXGOAT2 » Fri Sep 15, 2023 9:33 pm
White Auto used to sell Arvin branded stuff. I once had an Arvin 6-tube table radio.
