Shop class
Shop class
Post by Dollisdad » Tue Jun 25, 2024 10:28 pm
Re: Shop class
Post by Dollisdad » Tue Jun 25, 2024 10:30 pm
Re: Shop class
Post by Dollisdad » Tue Jun 25, 2024 10:36 pm
Re: Shop class
Post by Dollisdad » Tue Jun 25, 2024 10:37 pm
Re: Shop class
Post by Wayne Sheldon » Wed Jun 26, 2024 1:38 am
I wish I could see more of the car in photo number eight. It appears to be a theatre or vaudeville group and probably has their names on the car. I haven't been able to pull it out (yet?), but I could swear I have seen those people in those costumes before. Anybody know who they are?
Susanne
First Name: Susanne
Last Name: Rohner
Re: Shop class
Post by Susanne » Wed Jun 26, 2024 6:23 am
Im guessing that the kid at the bress is learning the fine art of straightening on a manual press - my guess is he;s doing itusing a piece of pipe or tubing (looks unfamiliar as a car part), but using something like that he could look down the inside of the pipe and see if it's straight or not (which would be readily apparent) before trying it on something solid. Also trying to figure out what the kid working on the flywheel is torching (I think it's a torch he's holding). Then there's the guy up to his forearms in the crankcase of a motor (with field coil attached)... All in all a fun photo!
Re: Shop class
Post by TRDxB2 » Wed Jun 26, 2024 10:13 am
Pan straightening :shock:
Re: Shop class
Post by RajoRacer » Wed Jun 26, 2024 10:43 am
Great photo ! It appears that he using a T driveshaft for leverage !
varmint
First Name: Vernon
Last Name: Worley
Re: Shop class
Post by varmint » Wed Jun 26, 2024 11:12 am
27 Business, Vale Oregon is now 100 South Court Street.
The building remains intact as does the one across A Street.
Vern (Vieux Carre)
Re: Shop class
Post by Jerry VanOoteghem » Wed Jun 26, 2024 11:15 am
I think the whole shop scene is staged for the photo. For one thing, the press is centered over one of the troughs in the pan cover. I can hardly believe that if they were really trying the straighten the pan, they would be doing so by pushing against the still attached cover. Also, the guy with the driveshaft seems to be serving no obvious purpose in any kind of straightening set-up. The others also seem to be involved in other pointless operations.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Re: Shop class
Post by Charlie B in N.J. » Wed Jun 26, 2024 12:32 pm
Good Lord! that group on photo # 8 ! They look like the cast of some small time traveling show. “I’ll be back at 3 o’clock and you’d better have the mortgage money or you’re in the street!”
Susanne
First Name: Susanne
Last Name: Rohner
Re: Shop class
Post by Susanne » Thu Jun 27, 2024 5:15 am
Silly me, I didn't see the pan! Must be getting old!
I was looking at the pipe, rather than the pan, thinking it was just part of the press... :oops: It's the same way I was taught to take warps out of firearm barrels and tubing - you look down the middle, and when you have a "bullseye" with smooth sides leading to it, you got it.
The one guy checking clearances on the pedal to (aluminum) hogshead interface was a maybe, until I realized he was holding needle nose pliers to hold it... also, the guy heating up the ends of he magnets on a radiator bench was... um... interesting. Heaven help us, DO NOT let some AI get this picture, they'll start using it to instruct people how to "repair" their model T... :shock:
Hudson29
First Name: Paul
Last Name: O'Neil
Re: Shop class
Post by Hudson29 » Fri Jun 28, 2024 5:45 pm
I just love that moody atmospheric shot showing a rainy street scene. It could almost have been intended for the cover of a detective book. It would be interesting to know who took it and why. There is no discernable subject, its just a scene from life like a painting.
Paul
jiminbartow
Last Name: Patrick
Re: Shop class
Post by jiminbartow » Fri Jun 28, 2024 11:37 pm
Wayne. Here is another picture of the actor’s Model T in Newlife, Wisconsin. I found it by searching “General Store, Newlife, Wisconsin”. Jim Patrick
Re: Shop class
Post by Wayne Sheldon » Sat Jun 29, 2024 2:56 am
Thank you Jim P! A real day brightener to see this.
jiminbartow
Last Name: Patrick
Re: Shop class
Post by jiminbartow » Sat Jun 29, 2024 9:30 am
Glad to help.
jab35
Last Name: Bartsch
Re: Shop class
Post by jab35 » Sat Jun 29, 2024 10:19 am
Thanks, Jim P, I had looked carefully at that pic, curious about the Wisconsin connection. Thanks for figuring that out and sharing.
I'm sure Steve Jelf knew/knows all those WTMJ Personalities well, can't wait to hear his report
