Front Plate Oil Pump ID
henryford2
Topic author - Posts: 826
- First Name: Joseph
- Last Name: Andulics
Can anyone identify this oil pump? Thanks
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Front Plate Oil Pump ID
Really cute!!
I wonder if it is a “vane style “
Great find
Great find
Les Schubert
- First Name: Les
I have a generator that would work good with it as it has a distributor on the back of it
Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Les:
the pump looks very much like the pump on my Dodge Brothers … a similar pump was used on Dodge Bro. engines from 1914 thru the 4 cyl. era … it appears to be bolted to a plate that is attached to the Ford front timing cover … the DB pump came in a 2 or 3 bolt mounting depending on year and engine series and was a vane type pump ...always an optimist...Gene French
Les Schubert
- First Name: Les
Gene
Thank you for the information
All the best
All the best
