1925 Coupe Interior
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 1924 Runabout
1925 Coupe Interior
Post by Tadpole » Tue Jan 11, 2022 2:18 pm
I am redoing some of my coupe's interior in brown. Door panels, kick panels, carpet, and possibly the headliner.
Can anyone spare some pictures of their restored interiors?
My coupe has no windlace/weather stripping. Any reasons I shouldn't add some?
I would like to keep it as "factory" as I can, but I will be doing the work alone and could use some guides.
Last Name: Kuehn
Re: 1925 Coupe Interior
Post by John kuehn » Tue Jan 11, 2022 2:30 pm
I have a 24 Coupe I reupholstered. You mentioned that you might redo the headliner. The headliner goes in BEFORE the top goes on. Ford did it that way. It probably can be done without the top removed but to me it wouldn’t look right I don’t think.
Originally there was windlacing all around the doors.
Good luck and others I am sure will comment also.
I did mine in Grey and at the time it was a bit cheaper than the original style Brown wool.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Tue Jan 11, 2022 2:33 pm
Thank you John, that is good to know. In that case I would rather leave it be.
Post by Rich Eagle » Tue Jan 11, 2022 3:05 pm
This is the brown kit I put in my Tudor several years ago.
Not knowing, I put the headliner in after the top was on. It was possible but not the best way.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Tue Jan 11, 2022 3:35 pm
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Tue Jan 11, 2022 3:50 pm
Many thanks so far for the pictures and information.
I have noticed some cars have the seat pattern for door panels, and some have headliner pattern.
Is one more "correct" than the other? Both look good.
BobP
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 1914 tr, 1916 rdts, 1921 tr, 1923 rdst, 1925 cp. 1927 pu, 1927 tr.
Post by BobP » Tue Jan 11, 2022 3:55 pm
I have an all original 1925 coupe with all original interior, if you want to keep it that way, let me know, Thanks, Bob.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Tue Jan 11, 2022 4:28 pm
Thank you Bob, PM sent
Last Name: Kuehn
Post by John kuehn » Tue Jan 11, 2022 4:36 pm
The 24-25 T coupes look pretty much alike but for a few details. In late 24 Ford started using steel framed doors which may have some type of clips to put the panels on the interior sections.
My car is a mid-late 24 which has a wood framed interior.
Your 25 may have metal framed doors which may have some sort of clips to attach the panels. The earlier cars with wood framed interiors which used small finish type nails to attach the panels onto the wood.
Different kits have been made for T Coupes and not exactly alike. You can use different colors with stripes that would be correct for your car.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Tue Jan 11, 2022 5:17 pm
I doubt my ‘25 shown above is correct but that is the way the previous owner had it re-done. No reason I can think of why the seats are gray and everything else brown but it is what it is!😊
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Tue Jan 11, 2022 5:53 pm
Here is what I am looking at now, I am having a hard time matching material to my headliner. Does it look like it was redone at some point?
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Tue Jan 11, 2022 7:24 pm
I seriously doubt most folks went back to their Ford Dealership when it came time to replace upholstery. Probably went to their local small town furniture upholstery shop and bought any style and color that pleased them. Thus all the off colors and styles from original.
Last Name: Kuehn
Post by John kuehn » Tue Jan 11, 2022 9:26 pm
https://www.google.com/search?q=caudaro ... ent=safari
Go here and you can see almost the same material and color. Scroll down a bit and you can see it. I think what you have is caudaroy.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Wed Jan 12, 2022 6:36 am
I admit, now that you bring it up it looks and feels like corduroy. I think my best bet is to match it on the upper door panels between and above the windows, then do the rest of the door/side panels in the same pattern as the seats.
BobP
Last Name: Peterson
Post by BobP » Wed Jan 12, 2022 12:30 pm
Hi, here are the interior pictures of my original interior. I did not get your PM. I hope this helps, Bob.
BobP
Last Name: Peterson
Post by BobP » Wed Jan 12, 2022 12:52 pm
More pictures
BobP
Last Name: Peterson
Post by BobP » Wed Jan 12, 2022 12:53 pm
more pictures
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Wed Jan 12, 2022 1:11 pm
A hearty thank you to everyone for the pictures and insight. My headliner is interesting but definitely not original, thank you Bob for the pictures of your time capsule!
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Mon May 02, 2022 7:08 am
Can anyone spare a photo of where exactly the windlace attaches to the doors?
Last Name: Tannehill
Post by JTT3 » Mon May 02, 2022 3:58 pm
Hey just curious, does anyone have any extra trim pieces for the drivers side door? I’ve got the bottom piece where the inside handle comes out but missing everything else.
If it matters it’s for the wood framed door not the steel one if it make a difference. Thanks John
Post by Rich Eagle » Mon May 02, 2022 4:26 pm
Tad, the windlace attaches to the doorway under the upholstery panels with the panel brads.
