Winfield Model N parts
Roadsterguy
First Name: Rene
Last Name: Gonzalez
* REQUIRED* Type and Year of Model Ts owned: 1927 tudor
Post by Roadsterguy » Sat Aug 30, 2025 9:45 pm
NOS Winfield Model N parts lot. $400 for all shown in the picture. Located in La Mirada Ca. I can ship at your cost
babychadwick
First Name: Chad
Last Name: Azevedo
Re: Winfield Model N parts
Post by babychadwick » Mon Sep 01, 2025 1:14 am
Isn't that a model M bowl cover?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Sep 01, 2025 11:37 am
Early production model N carbs used a model M style bowl, later used a S style bowl
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Sep 01, 2025 12:10 pm
Pretty sure the Model N cover is larger than the Model M cover. Just went thru this with Rene. The Model M covers are 2 3/4" across the wider mounting screw spacing. This cover is wider than that. Just FYI. Tied to call Winfield, but one answered...............
Roadsterguy
First Name: Rene
Last Name: Gonzalez
Post by Roadsterguy » Mon Sep 01, 2025 4:28 pm
The N model cover looks very similar to the the M model but the N model cover is larger
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Mon Sep 01, 2025 7:36 pm
Just a good bit different than my N....
Roadsterguy
First Name: Rene
Last Name: Gonzalez
Post by Roadsterguy » Mon Sep 01, 2025 8:23 pm
Is that a later production model N?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Sep 01, 2025 9:22 pm
Here’s a page from the 1930 Winfield catalog showing the S style bowl. Don’t have any documentation showing the M style bowl, but here an old thread about the model N carbs, where both styles are discussed
https://www.mtfca.com/discus/messages/5 ... 1451433153
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Sep 02, 2025 12:12 am
Checked today- the MODEL N cover screw spacing on the two screws closest to the throttle body measures 2 7/8" where the Model M covers screws are spaced 2 3/4" apart. Side by side, the two are noticeably different.
M on Left N on Right
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Tue Sep 02, 2025 8:02 am
Good to know mine is the "later" style. Seems these carbs are barely big enough for a T....
