Winfield Model N parts
Topic author - Posts: 17
- First Name: Rene
- Last Name: Gonzalez
- * REQUIRED* Type and Year of Model Ts owned: 1927 tudor
NOS Winfield Model N parts lot. $400 for all shown in the picture. Located in La Mirada Ca. I can ship at your cost
- First Name: Chad
- Last Name: Azevedo
- First Name: Kevin
- Last Name: Pharis
Re: Winfield Model N parts
Early production model N carbs used a model M style bowl, later used a S style bowl
- First Name: DAN
- Last Name: MCEACHERN
Pretty sure the Model N cover is larger than the Model M cover. Just went thru this with Rene. The Model M covers are 2 3/4" across the wider mounting screw spacing. This cover is wider than that. Just FYI. Tied to call Winfield, but one answered...............
- First Name: Rene
The N model cover looks very similar to the the M model but the N model cover is larger
- First Name: Chad
Just a good bit different than my N....
- First Name: Rene
Is that a later production model N?
- First Name: Kevin
- Last Name: Pharis
Here’s a page from the 1930 Winfield catalog showing the S style bowl. Don’t have any documentation showing the M style bowl, but here an old thread about the model N carbs, where both styles are discussed
https://www.mtfca.com/discus/messages/5 ... 1451433153
- First Name: DAN
Checked today- the MODEL N cover screw spacing on the two screws closest to the throttle body measures 2 7/8" where the Model M covers screws are spaced 2 3/4" apart. Side by side, the two are noticeably different.
M on Left N on Right
- First Name: Chad
Good to know mine is the "later" style. Seems these carbs are barely big enough for a T....
- First Name: Rene
Model N's were more like overkill for T. They were big carbs.
- First Name: Chad
It was a joke, I will probably use my N for the tow car.Roadsterguy wrote: ↑Tue Sep 02, 2025 12:18 pmModel N's were more like overkill for T. They were big carbs.
